Well, in a way, yea. But with this phone, every update has been the same version of android, what's been updated is the kernel to block towelroot.It has to do with both.
Did you update OTA, or with the ROM on here, or was it stock zv4?if the method i used that worked works for someone else, it will be a whole lot easier then downloading a bunch of gigabytes it only a few megabytes and an active interenet connection
If you go find the pc application for iroot, not the apk you install on your phone, but an .exe you install on your computer, it is a more powerful version of the one on the phone, it will still root the phone even on the zv4 update. i know this for a fact, as i rooted my phone after the update without cwm installed.
here is the link for the pc download: http://www.mgyun.com/en/getvroot
I'm not sure he even has a Volt. If you are on stock zv4, by all means try iroot and let us know if it works. If it doesn't, utilize the guide I've posted above.Is your Volt the Boostmobile version? And did it come stock with the ZV4 ? thanks hope to try this method this week.
Based on what theminor19 is saying, I guess it should work. Won't hurt anything to try it. Please report the results if you do.Is there any more info regarding iroot.....Has anyone else tried it yet?
Not surprising. Software like this often get flagged as a virus because they use virus-like methods to accomplish their goal.cant even get it to download.....its really freaking out my antivirus on pc...keeps being blocked.....same with apk download to phone....avast android protection blocks it
Are you saying others have not been able to download it or if they have it hasn't rooted the phone.
A few people have tried it, and yes, USB debugging was enabled, but it's not working.if you do get it to download make sure to check usb debugging under developer option on your phone. if you dont have developer options on your phone go into settings and tap the build number under about phone about 7 times and you will get a small pop up box saying you are now a developer. this needs to be checked to get it to work.
At least two people have tried it, actually. I appreciate your effort.in the other forum only 1 other person says they have tried it so i am just trying to help
