Help My Location problem
winter20
Hi,
First of all, I'm sorry if this problem is already here, but I couldn't seem to find it so here I go.
I'm having issues with my HTC Desire HD detecting his location. I tried to locate it via HTC Sense and it says that my phone is in another location (maybe 20 km distance from where it actually is). I also tried to simply locate my phone through Locations and it shows the same location, so I don't think it's from HTC Sense, it's from my phone.
Any ideas what can I do in order to make it show the correct location? Thanks in advance!
Try this -
Tried a method which seems to have solved the problem (I hope). Downloaded app "GPS Status" from Android market.
Then followed instructions as found on this site
(GPS Fix For CyanogenMod 6 On The Nexus One | Android News, Reviews, Applications, Games, Phones, Devices, Tips, Mods, Videos, Podcasts - Android Police), originally advice for Nexus One owners:
Take your SIM out of the Nexus One
Power on the device
Turn WiFi on
Turn GPS on
Open application: GPS Status
Go into its Settings menu
Click on GPS and Sensors
Click Manage A-GPS state
Click Reset
Click Manage A-GPS state again
Click Download
Now put your phone on a stable, straight surface in order to enable the phone to get a lock. This time, you’ll see your
Says it's for the Nexus, but works on the DHD too. :)
It works for any aGPS equipped device. I use it on my Droid when it has problems getting a GPS fix.
If you're not getting GPS accuracy (down to ~3m) then you're not using GPS. Try using GPS Status to clear your aGPS data as suggested above and see if your GPS receiver is then able to obtain a fix. You can use GPS Status to determine if the receiver is able to get a fix.
there's a thing that says Fix/Sats 1/1, so I guess I have a gps fix, but the correct location of my cellphone is still wrong. Any other suggestions?
