Accessories My M2 Car Mount pictures... love this thing
Which case did you use? I used a cheap silicone case from Amazon and it doesn't seem to want to stay on. I used super glue, and when I went to put the phone on the dock, it came off. I'm thinking I might have better luck with a Flexi case (similar to the Verizon high-gloss silicone, I think)??
Is the actual mount itself removable? And if it is does it leave a nasty residue behind on car, because if it does not I'm all over it :D
Also thanks for the pics
this answers some questions I had regarding the mounting placement, and whether or not you could use this for landscape and normal .
Do you think this would work on a Seidio II case?
Thanks OP! For $9.99 shipped, this is a steal!
Go here: http://www.wiredforless.com/product_p/soundm2.htm
Enter WOOT as the coupon code for $20 off the unit price for as many as you want, then add $5 shipping for the lot! SWEET!
-kj-
EDIT: got this case on ebay for $2.95 shipped: http://cgi.ebay.com/Rubber-Hard-Cas...ewItem&pt=PDA_Accessories&hash=item35aab89a56http://rover.ebay.com/rover/1/711-5.../eBayISAPI.dll?ViewItem&item=230497491542 will stick the adhesive mount on this, not my regular case (certainly not the phone, lol) ... just a few seconds to set up in the car and I'm good! Have been looking for a car mount for a while. Off to Monoprice now for a car charger!
