Help My Modes
bugger
I am messing around with the "My Modes" on my slide and I have a couple of questions. I want to creat a mode "work" that I can use while at work. Basically I just want some different things on my home screen and I want it to vibrate as opposed to ring. I noticed that if I change it to vibrate in "work" mode, when I change to any other mode, it stays on vibrate. Is there a way to set a certain ring/vibrate that adjust depending on your mode?
I also noticed that if I switch to vibrate and then back to normal, my ringer setting is really low and now set on high like it was when I put it in vibrate. Does anyone know how to fix that so when i exit vibrate it goes back to normal ringer mode and volume?
Thanks
When you changed it to vibrate, did you use the buttons on the side? This will change it for all modes. To make it change only when in "work" mode, scroll to the bottom of the myModes screen and make the ringtone Silent. As long as under settings>sounds and display vibrate phone is checked, it will vibrate.
Thanks! So when I am in "work" mode, change the ringer and notification to silent. As long as normal settings have phone vibrate when being called, etc... it will vibrate. Then when I switch from "work" to normal, it will ring without me having to go and adjust the ringer volume etc... I think I got it!!
