My Own Custom Triumph Desktop Cradle
Prey521
Since we don't have any real accessories for the Triumph yet, I decided to use the charging cradle from my old Blackberry Storm2 and it's not too bad. The only thing I had to do was put some sort of support behind the phone so I'm using a Post-It stack :D
Prey,
Would you have a link to the cradle you're using here? I just want to make sure I'm looking for the correct one. You could probably glue some type of backing to support the phone on the higher end of the cradle. Looks Good!!
Thanks
I just bought the OEM version because I also wanted a dock. Got the OEM from Amazon.com for $9.00! I used a couple of small sticky back velcro on the stand (not the phone) and it sit up perfectly and you can't even see the black velcro. :D
Line up, stick to base, put loop velcro on top (sticky side out) then put sticky to sticky together and leave soft side out (that is where the phone rests)
Thanks for your idea! works perfectly.
Do you have a link to the one on Amazon you purchased?
Thanks for the info....
