Help My Phone Doesn't Lock Anymore
It used to lock whenever you pressed the end button andwhen you cliced end again, you had to slide the buttonto unlock it. But suddenly, it stoped doing it. So everytime I press end, it just goes right to the home screen. Anyone know what happened?!
Thanks! I think I've found a solution. It looks like a lot of other people with the Samsung Moment have experienced this and that using the app Spare Parts fixes it.
mine does the same thing... the end button turns the screen off but it doesn't lock. a power-cycle fixes it for a bit, but it does it again after a bit
i'm on a DI03 rom, btw
factory data resets fix all software glitches... just remember to take note of your apps and sync contacts, calendar and gmail
