Help My phone is going nutz maybe or something
heres my phone model its ZTE N800 i just patched a application to clone it and after that it reboot and when i see the andriod logo the creen is turning black and after few seconds the screen turn rainbow color i cannot usb debug it i rest the phone I clear the cache to and its still disame sow plzzzzz i need help to fix my phone
:Sigh: [emoji49] You don't "patch" an app to "clone" it. Be Str8, you were using LuckyPatcher or similar app to get free stuff. The problem with that is it messes with data and Google Play services, both of which can cause a phone to lock up, boot loop, or F/C (force close). The only way to fix this is to boot to custom Recovery wipe & reflash your ROM + Gapps
I mean i use a lucky patcher to clone a app and my model phone is zte n800 i really need a help to find a file sow i can save my phone plz i need a file for it can anyone find a file
Thank you for being more clear/up front this time
[emoji49] Do you at least have TWRP installed? [emoji49]
I ask so that we have more information in which to properly help you..
Edit: I also own a ZTE Warp4G, which is the hardware equivalent to the ZTE Awe.. So many of my files may indeed work
OP: "no i dont have the twrp installed and i cant access my phone bcoz my screen is rainbow and maybe my main bios is damaged"
My reply:
Then ur done. Scrap it. A serious rule of thumb: NEVER Mod/patch a system app unless you have a custom recovery and/or a sure fire way to fix your error. In this case, you screwed yourself. If you'd already had TWRP installed, I'd walk you right thru the process.. Sorry bro.
