warrior_84
I just responded to someone's thread asking if they should get an Optimus G (I had a lot of bad things to say about this phone) and then I decided maybe there are fixes for my problems...so here goes (I have a Sprint Optimus G 4.1.2, LS970ZVB, I believe everything is up to date):
It takes forever to send texts. After I hit send it's added to the conversation but takes forever to say sent. When the phone was new this process was much faster.
It seems like every couple days I have to reset my phone to start receiving text msgs, after it boots back I receive a grip of texts.
It is often searching for gps signal, even though my maps works. I have everything enabled but it says my location service is off and doesn't give me any google cards, although every once in a while one will pop up and say how far I am from work or home etc. (I understand that problem is fairly common on other phones as well??)
Performance is unpredictable...sometimes it's fast and sometimes it's a dog. I have not installed very many apps (10) and I have plenty of available space (>17 gigs). I clear app cache sometimes but it doesn't really seem to help as much as rebooting my phone does. But like I said, it'll go from back and forth from fast to slow and I'm not sure why...
I'm open to doing anything with the phone that'll fix these issues... whether it be running a different rom or whatever, but at this point my phone is completely stock. Well I appreciate any and all help that you guys can give me. Thanks
Lee
Lee
