My phone wont stop vibrating!
Hiya,
I have changed (all settings I can find) to stop the phone vibrating when I get a text, when I type numbers on the keypad, to no avail! Anyone direct me where I can do this?
PLEASE do not put Setting:Sound & Display as all the vibrate options on there are turned off already.
I did send of the phone to be fixed as i smashed the screen and the latest software upate was completed on it however the vibrating option doesnt seem to be here :(
Welcome to Android Forums! In your text app, go to settings and uncheck notification...also in settings-keyboards uncheck vibrate on touch.
Good luck!
Welcome to the Android Forums!
In Android ringtone/vibration settings are typically local to each application...
