sentinelace
I have mr2 third. I cannot seem to find a radio that gives me more than 2 bars. What gives?
to see your true signal strength go into settings and about phone, and then status. The lower the dBm the greater the signal strength. About -65 is perfect signal
but you are correct I notice no significant increase in speed from 65 to 45 db only think less power would be used by the phone.In CM settings you can change your signal icons so its shows the dBm instead of the bars
Hi,
I have a tower near my house and when standing near it I have seen the signal go to as low as 45 dbbut you are correct I notice no significant increase in speed from 65 to 45 db only think less power would be used by the phone.
Thanks,
Bryan
Where? I don't see that option in CM settings.
Just one more reason to love CM7, and Android in general.
