I apologize for no original pics but my current camera blows hard unless actually using the light on the surface of the sun.
First the basics.
The Skytex Skypad Alpha comes in your standard MID type box. You can tell the revision of your pad, A or B, by the image on the top of the box. If you have the green cloudy field you have an A, if your have the amber sunset field it is a B.
The Skypad comes with a soft cloth case, felt screen swipe, earphones with their own volume control., USB cable, stand for horizontal or vertical use, charger, and in my opinion the greatest pad accessory in the world, a stylus with a screw on cap that plugs into the headphone jack of your pad. Why don't all pads?
The style of the Skypad is sleek and simple. I mentioned previously it feesl kind of strange but pleasant in your hand when compared to other pads. Like an e-reader on steroids. It's slender with a nice solid feel, on the ends it has a brushed metallic trim, the back has a black coating that has a nice no slip feel to it. You have the Menu, Home, and Back button on the right front side of the face and the Skytex logo on the bottom. The bottom right side has you Mini USB and power adapter ports, the top right side has the headphone jack and power button. On the back you have your speaker and the reset pinhole.
The specs are as follows: Screen
Type: 7
First the basics.
Type: 7
