I will try to keep this relatively short as others have posted similar messages. First, I use these widgets/toggle switches on the screen to the left of my home (they are always off unless I need the service)
1. Standard mobile settings widget (settings, mobile data, wifi, auto sync, roaming)
2. Bluetooth toggle
3. Auto keyboard rotate toggle
4. 2G-3G toggle --> this is actually a shortcut to mobile network settings, then click network mode, and select GSM only (2g) instead of GSM (2g)/WCDMA (3g) auto. Dropping your phone to 2g will save you boat loads of power!
5. Brightness widget (usually keep brightness at around 20-25% and 0% at night)
6. GPS toggle
7. Airplane mode toggle
8. Downloaded app - green power (automatically turns wifi / data on off with screen)
9. ATK advanced task killer, set to auto, hyper, in settings so it kills all apps not being used
Those are all very useful, and dedicating one screen to widgets and toggles is a very quick way to activate the services you need, only when you need them to save a ton of power. After you have all those, lets look at some other settings.
- Disable all vibrations on key strokes, they suck battery power.
- Display: Low brightness is big, see above note. Also screen timeout (30 seconds, if you really wanna Nazi it go 15). Also on this screen you have auto-rotate screen. I leave this disabled, and use the toggle to activate. Keeping this always activated will use more battery.
- Accounts & Sync: Background data is checked, auto-sync is not (toggle switch). Google, HTC Sense, News, Stocks, Weather are all set to manual. You can change any of these depending on your needs, of course.
- Location: Use wireless networks ON, Use GPS satellites OFF, Phone finder ON, Intergrate Google Navi ON.
- Power Saver: Disabled. (may seem counter-intuitive, but everything it does were doing already just from 100% battery life not 30%).
- Some where in the settings you can also disable on screen animations, thats a good one too for saving battery.
- I keep a dark background with no moving parts, I dont know how much this helps with this type of screen but hey what the hell.
- Disable sounds for unlocking phone.
Cheers guys,
Matt
2. Bluetooth toggle
6. GPS toggle
Cheers guys,
Matt
