My Weather Clock help!
So I'm using the widget that came with the phone called "My Weather Clock." Its simple, and I don't need anything flashy. Last night was the time change, and my problem is, is that the widget didnt set the clock forward, so my main phones clock is 6:48 but the widget reads 5:48. Is there anything I can do to change this? Its highly annoying...:confused:
ALSO: My phones a Huawei Ascend on Metro
Mine is doing the same exact thing. Same provider same phone. What's weird is every once in a while I'll look and they're both the same time, then bam...back to an hour behind. It keeps the right time if I don't set my city. Dumb. lol :cool:
I have been trying to figure this out since Daylight Savings Time!! I called Metro PCS customer service and the person who helped me had to reset my system settings within Metro PCS and this seemed to work. The time on My Weather Clock is now correct. This process took 5 minutes and had no negative effect on my phone at all. Hope this helps!!
I called Cricket and the rep told me to turn Airplane mode on then off. I tried it but the hour on my Huawei My Weather Clock widget will still be off by 1 hour :rolleyes:. I'm thinking I'll see what's out there in the market.
If you have Task Killers, such as Advanced Task Killer (ATK), don't kill widgets.
Long-press on the widget then select ignore.
If you kill a widget the time will stay the same.
go to market and use a better/good looking weather clock widget, better than stock and more customizations...:D Or put in airplane mode for about a minute than take it off air plane mode, or try *228 if your on metro...but i think a new widget would be best.
