I can't keep my wifi connected on my Droidx!! Scanning... connecting.... connected...then a few seconds later the wifi icon disappears and it repeats the process seemingly forever.
I've discovered that if I use the wps push button method to connect it was stay connected until the wifi goes to sleep when I tries to reconnect I get the scanning...connecting...connected loop.
I've tried different settings in my router (wpa/wpa2 just wpa, just wpa2, tkip, aes) I refuse to go below wpa encryption.
My current settings WPA2 AES. I'm running a Linksys WRT400N dual-band router latest firmware, 2.4ghz mode set to mixed b,g,n.
Oddly enough, during the time it took my to write this it connected itself and it seems stable now (at least until I let it idle). Phone probably knew I was on here complaining about it lol
but any help you can give me to obtain a wifi connection better without having to spend 15mins each time trying to get it to connect would be great.
