Is it available? I am looking on XDA and do not see it
If you already have myn warm installed just hold down the power button like your going to shut off the phone. Go to restart. Then you can select recovery. From that point it will boot into rocovery. Then you can select nandroid backup/restore. After that select your most recent back up and restore it. I would suggest doing that and reflashing the rom. Make sure you WHIPE the device when flashing it. That will clear all conflictions.I have a backup of some sort. I followed the steps that Matlock posted to root the phone, and before I flashed Warm I made a backup / recovery image. If that's considered a nandroid backup, then yes, I have it. But not sure how to do it manually. I'm pretty new at this stuff, but good at following directions.![]()
Myn will be releasing the RLS3 to the public this evening. Not sure what exact time. Doners that donating already have the update. I'm assuming you have to flash this rom like any other and not an update.Is it available? I am looking on XDA and do not see it
Yep...I donated last friday and have been using RLS 3 beta ever since. I love it, and I'm sure the full RLS 3 will be even better. Myn's is the first and only rom I've used since I rooted. I really see no need to try any others. None of the other roms really have anything that appealing to me over Myn's. It's just simple and pretty, runs fast and stable.
If I donate will I get the rom right away?
Not right away, but the same day from what I've seen. It should be released this evening though. I can tell you it's worth the donation. I've been using his rom since rls1.
I donate to him and have had the final for about 24hrs. It's great! I didn't think i'd ever leave RLS 2, but.....
The public release is this evening at some point.
Slugbug.....you say "Everthing works -4g,etc.". Just to calrify. Are you saying everything works MINUS(as in except) those items....or where you just using the dash sign to break up your sentence????
