Needforspeed
Which should I use
Which should I use
) and see what works best for you.I had read in another forum that setting the setcpu main scaling to "smartass" in combination with netarchy-toastmod-4.2.1-cfs-bfq-havs-more-smartass-universal (More Aggressive Undervolting) that also utilizes "smartass" scaling will cause a conflict. I am not using profiles but what main scaling should I use in setcpu?
Also, if I DID choose to use profiles, what scaling should I use for most effective battery life?
TIA
So even with a HAVs kernel like net 4.2.2 you can use profiles in setcpu effectively with the governor set to something other than smartass?
