Root Myns Warm 2.2-Couple of issues
chiadrum
OK just flashed this and it is cool and superfast.Just a couple of weird things.
I don't seem to be able to see Apps that I have downloaded and installed from the Market like Titanium Backup-I have the Pro version.I can go into settings-manage apps and it shows Installed.Same thing with a couple of others.
One other problem is that in certain Apps the text appears in a frustratingly light color-almost no black at all.
Does anyone know how to remedy these issues?
Just what ROM Manager prompted me to wipe.That's worked so far for flashing ROM's which is Data and Cache I guess.I can manually wipe davlik now if you think that will help.
Nah, Dalvik is supposed to be wiped before you flash the ROM, not after. The dev recommends a full wipe (check the thread in the ROMs section, which has a link to his xda thread). So you should probably be doing it from clockworkmod recovery, instead of ROM Mgr which sometimes seems to give odd results for some people. (edited to add: wiping the dalvik cache is under the advanced options in clockworkmod recovery). Dalvik wipe may not be critical, but I'd definitely try again from clockworkmod, following the dev's instructions precisely.
Also, did you restore any system data with Titanium? If so, that may be the problem - system data doesn't migrate at all well between ROMs.
If it's none of those things...well, Warm acted a bit funny when I tried it too, although not in the same way as on your phone. :( You might try the thread for that ROM if nobody else chips in here.
OK,I re-flashed the ROM doing the manual wipes and I had the same result.
Then I downloaded and installed the free Titanium Backup and that worked fine.Strange.Just a Warm 2.2 glitch I guess.
Phone seems to be running great besides that.All of my data did restore although Verizon Backup Assistant is apparently gone forever.Doesn't matter as long as I get my data.
Phone is super smooth and fast with no bloat and some cool features now.Thanks for the feedback.
log in to backup assistant online and export your contact list in csv format, then import the contacts in to gmail and now everytime you flash a new ROM all your contacts will be sync'd automatically :)
Most ROMs cut out backup assistant now-a-days, but if you still want to install it download this zip, put it on the root of your sd card and flash through recovery like you would a ROM (no need to wipe cache or anything).
http://dl.dropbox.com/u/16147243/Android/App_Backup_Assistant.zip
Its posts like this that make me wish I could hit "Thanks" 20 times!!!
so . . . .
Thanks!Thanks!Thanks!Thanks!Thanks! . . . .
