Kasey Clark
First let me say that I'm pretty new to this and will need pretty detailed instructions. Also thanks ahead of time for all the help.
I have already rooted my MyTouch Slide. I am currently running CyanogenMod 6.0.0-Slide-RC1 with ClockworkMod for Recovery.
The problem I am having is that 1) I am unable to flash a different Recovery and 2) I am unable to flash ANY other ROMs nor can I update the one I have.
I am using Ubuntu 9.10 too if that makes any difference. I have tried several different Recovery images and each time I get the error : not enough space..... and even right after a I do a memory wipe. I could really use some step by step directions for getting a new Recovery. On a side not I also would like some instruction on bloatware removal. I have android mate and have used it to remove some of the files associated with said bloatware. For example Amazonmp3. I have gone into the sys/app folder and removed all the files there. Now I keep getting a "Amazon mp3" has forced closed....." when I have not even opened the app. Then I went to data/data and removed all traces there. Still the app remains and with constant fc. So the point is I could also use some step by steps to get rid of such apps.
