Help MyTouch E379 SIMPLE MOBILE HELP!
Can someone help me with the APN settings to make sure I have it set up correctly? I can make calls, take calls, send texts, but cannot receive texts. I just need to make sure that I have it all set up correctly.
FYI - I did port my number from T-Mobile a little over 2 hours or less ago. Could that be the issue??
The instructions are found on the Simple Mobile website. Use the instructions listed for the Optimus T if the myTouch isn't listed.
