Help N7 player
nefcpainter119
The player is now saying I don't have a 2.3 device, which means no equalizer. Does anybody know why it's doing this? I recently flashed the new beats zip maybe they contradict with each other? Not sure. But don't understand why it's says my device isn't 2.3 or higher. Any suggestions?
I'm not sure what beats zip your talking about but if you made a nandroid like you should b4 flashing even the smallest of things use it. Imma look into this beats zip if I find what it is maybe ill have a new input
Currently I'm using WCS 1.5, but 99% of the time ill be using Unitology... So I don't know if the ROM makes a difference :confused:
