NAND Memory Issues
reilus
This should make you laugh a bit:
New research shows that far more than wireless network or CPUs, the NAND flash memory in cell phones, and in particular smartphones, affects the device's performance when it comes to loading apps, surfing the web and loading and reading documents. In tests with top-selling 16GB smartphones, NAND flash memory slowed mobile app performance from two to three times with one exception, Kingston's embedded memory card; that card slowed app performance 20X. At the bottom of the bottleneck is the fact that while network and CPUs speeds have kept pace with mobile app development, flash throughput hasn't. The researchers from Georgia Tech and NEC Corp. are working on methods to improve flash performance (PDF), including using a PRAM buffer to stage writes or be used as the final location for the SQLite databases."
Flash Memory, Not Networks, Hamper Smartphones Most - Slashdot
