Nand restore Via ADB
v01rider
Android Expert
not my directions, but they worked! i wanted to share after doing a search and not coming up with anything. all credit goes to Dr. Dre
Here's the solution :-
1. Start phone in recovery mode, by turning it on while holding "Home" and "Power"
buttons.
2. Plug the phone into the PC with a USB cable
3. Start Windows Command Prompt on your PC, by pressing Start on your PC and typing
CMD into the run or search bar depending on your operating system. Then selecting
Command Prompt.
4. Within the command prompt window, change the directory to the one your adb tools
are by typing the following:
cd c:\sdk\tools
5. Then type:
adb shell
6. Now type:
mount /sdcard
7. Now you need to change directory again to the one holding your nandroid back-up
data, so first type
cd /sdcard
8. Then type:
cd nandroid
9. Now you need to find the specific name for the folder that holds your Nandroid
Backup images, so type:
ls
and view the list that appears.
10. Now to enter the folder you want to back up to type
cd HT**********
obviously replacing the *s with your numbers and letters. FYI the number string
is your Device Serial number.
11. Again type
ls
12. Now to enter the folder you want to back up to type
cd BCD***-********-****
obviously replacing the *s with your numbers and letters. FYI the format of
these digits is BCDXYZ-YYYYMMDD-HHMM from when the back up was created.
13. Now type:
nandroid-mobile.sh restore
14. Just press enter to select default.
15. Double check that the Default backup that is found is the one you want then
press enter again. Your selected backup will now be restored.
Why not just turn on your phone while holding the down volume and power buttons and do this from your recovery program?
