Root NAND Unlock
When NAND unlock is finally released, is it likely we will need to boot into recovery again or will it be application based only requiring root permissions? I know we truly won't know until it is done, but based on past NAND unlocks, which is it likely to be?
Based on past locks, you will be able to use an application like RootExplorer to mount the /system as R/W and you can change files on the fly. Currently you are able to change the /system to R/W using RootExplorer, but when you commit the changes the phone reboots since the mount was read only.
i think he means to apply the hack. i think he is asking if we have to do it in recovery or is it going to be app based.
Ah, my mistake
Their twitter page is a bit vague on what exactly needs to be done, all we know so far is that the phone does need to be rooted prior to using their utility. I believe we will need to apply their patch through recovery mode again as it will probably be changing system files.
Purely speculation though.
Ah, my mistake
ahhh...that sucks. that is the only hard part! took me two days!
