Root Nandroid backup/restore default options
Hamnrye
I've been meaning to ask this for awhile. When creating a Nandroid advanced backup a few of the default choices/items are not checked for backup. I usually check those so everything is included, is that correct and/or what is the difference? Same on the restore, there are 3 or so options that default as not checked on the restore. Should those be checked to restore or left unchecked?
