Nandroid restore issue
00h2itr
RA 1.6.2
Newest Zen ROM, however it's happened since I was on Fresh 2.0d, Zen 0.9.6.3, and now on the newest Zen.
I can perform a Nandroid backup without issues or errors. I can use a file manager to confirm its there.
I am not running into space issues on the Class 6, 8 GB memory card. To confirm, this happened on the stock card.
Scenario...
I boot into recovery, go to Backup/Restore, Select Nand Restore, locate the file I changed the name of (Have tried without changing name as well) then it goes to another screen that has a file name of BDS-201009023-0204. I imagine this is a date stamp of sorts. After I select that, I get the "restore to BDS-20100903-0204" press home to confirm. I do that, it says Restoring for about a second, then has an error.
Error : run 'nandroid-mobile.shrestore' via adb!
I have never been able to perform Nandroid restores, but have been able to do backups. I've tried on 3 different ROM's.
The only thing I can think of that may have caused this is at one point when I first got the phone, and rooted I had 1.5.2 and then upgraded to 1.6.2 I never tried a Nandroid on 1.5.2 before changing to 1.6.2. But that's the only thing I can think of when it comes to Recovery that may be the issue.
So, thoughts?
Thanks Kelmar.
I'm going to see if that works singularly (if that makes sense) but I want to fix this permenantly. I'd hate to be forced to have a PC around when I want to Nand Restore.
Yeah, I read way past post 10 to where it came across a blank file of the 6 in the Nand file.
I think my issue resides in my "upgrade" from 1.5.2 to 1.6.2.
Will report back later on my findings.
Ok, RUU'd and now rooting back...
I get to step 9 of this guide:
http://androidforums.com/sprint-hero-all-things-root/162821-how-root-sprint-hero.html
I get the following error:
cannot create su: read-only file system
Now, I'm not a linux guy but I know what this means... I don't have the proper permissions.
Now on step 7 it has the following syntax:
mount -o remount,rw -t yaffs2 /dev/block/mtdblock3 /system
Now I think that meants it's mounting with Read and Write permissions (Linux, read, write, execute) so I "should" have permissions and I don't get any error messages when I perform step 7. I have gone back and tried it over and over again, but not happening.
Need a linux guy to decipher the syntax and let me know how to fix it.
LOL, ID10T error on my part...
I put a space before the RW... whoops
Now I'm getting access denied pushing the RA to the SD card... Mount? Nope... format.
Was partitioned previously for A2SD.
Well Kelmar, seems my "update" from 1.5.2 to 1.6.2 was the issue.
RUU'd, rooted, added 1.6.2 from the get go and then restored the Nandroid I made before RUU'ing.
Working great now. I can start flashing all sorts of ROM's knowing I can keep coming back to this.
I get that error a lot. At least you recovered from it on your own, lol. It's worse when someone else points it out to you!
Yup guys, it's all working now. If anyone in the future has questions about it, just PM me.
Kelmar, thanks for letting me bounce idea's off ya. Sorry for the full inbox. :)
