N novarider Android Enthusiast Sep 8, 2010 #1 What is the difference in these? I can do a nandroid backup or a nandroid+ext backup.
tsipa Android Enthusiast Sep 8, 2010 #2 novarider said: What is the difference in these? I can do a nandroid backup or a nandroid+ext backup. Click to expand... Ext backup is a backup of the partition on your SD card. If you do not have your SD card partitioned then there is no need for you to back it up.
