Derrick2203
Member
Anybody know how or where I can get the Navigation Bar of a Galaxy Nexus for my Esteem?.. (If there is one) Thanks
The keys are still working fine. I was just curious if it was possible and try them outThis? http://androidforums.com/esteem-all...pdated-6-14-12-softkeys-led-light-toggle.html
Not sure why you would want to take up screen space when you have hard keys. Unless the soft buttons have stopped working.
The keys are still working fine. I was just curious if it was possible and try them out![]()
Ive searched everywhere for a mod or application for it but nothingYeah I'm not sure. I haven't seen much about trying it out. Not sure if that link would help. If you could change the dpi size, it could be made smaller otherwise you'll lose about 1/4" of screen space.
If you try it out, post up your results. Im sure others would like to know the outcome![]()
Ive searched everywhere for a mod or application for it but nothing![]()
NoThe link shared above didn't work?
That's exactly what I'm looking forI remember I wanted that too but the only thing I found was this
androidandsandu.blogspot.com/2012/03/how-to-add-virtual-softkeys-navigation.html?m=1
But I don't know how to work with codes and stuff. I read through it and all it gives you are the source codes and files
No![]()
That's exactly what I'm looking forBut I don't know how to work with codes and stuff. I read through it and all it gives you are the source codes and files
