hemmadroid
A Verizon rep told me the X can navigate either by satellite or cellular reception, but my X instructs me to turn on the satellite receiver. Is there a way to navigate with cellular?
I don't think that google nav will work without the gps turned on...google maps will give you an approximate location but won't nav
Think you have a big typo in your cell accuracy.This. Cellular triangulation is not tight enough for the google maps to know what street you are actually one.
Navigation needs that resolution to direct you, so GPS is required.
Cell: 10 yard diameter circle (IIRC)
GPS 9 to 13 feet with direction and a center point
