Navigation Apps?
sampo
Could someone give me the rundown concerning the plethora of Navigation Apps. that seem to be available with 2.1
Why so many, which is ultimately the best one? I think there are 4 different ones with 2.1!!!
Sprint Navigation, Navigation (Blue Arrow), Navigator, and Maps...
Personally, I like the Sprint Navigation. I've not really had any issues with it. As such, I've not tried any others. Is there something you don't like about it?
Just curious as to why there are so many!? Is there any way to disable/delete the ones I don't use?
Also what are the main differences between them, feature-wise...
Sometimes Sprint NAV gets lost, have yet to have the same problem with Google NAV
I like the Sprjnt NAV option that allows you to create destinations on with the web interface and pump them to the phone.
That said I LOVE the fact the you can enter GPS coordinates into a GMail contact and have them "magically" appear in Google NAV
