Help Navigation Instructions for DROID Bionic
fweiss1
I'm looking for detailed instructions on how to use the Navigation on my Bionic using the vehicle dock. It seems that it works differently in the dock vs. without the dock.
Motorola claims the only instructions are the quick start guide which shows how to install the vehicle dock only.
For example, how do I add favorites/stars? I can do it easily without the dock.
Thanks you in advance for any support you can provide.
