bryanheath, thank you very much for the extensive answer - very kind. I am still on the lookout for a 7" Honeycomb Tablet (if they ever appear on the scene). But then I would like to use it occasionally as a Nav - mostely in France and Germany.
You are right. The 10" tablets are just too big to haul around. Might as well haul one of my laptops. The 7" Galaxy with Honeycomb would be nice. But up to now there is not even a rumor about it. But fortunately I am in no hurry.
Depends on the specific app you're talking about.How does that compare to a navigation device like Garmin. How does that compare to a navigation device like Garmin. Does one have to buy the maps and the updates and is there also voice output.
There is no "Android NAVI". You're referring to Google Maps Navigation. There are many GPS nav apps for Android. Some download map data, others store it locally. As with any other set of options in life, each has its pros and cons. There's no one-size-fits-all solution.I use android NAVI all the way!
If you're using Google Maps Nav and you'e not happy with the voice then try loading another TTS engine on your device. SVOX and Loquendo (neither are free) both have better TTS engines than what is stock on many devices. A better TTS engine doesn't just benefit Google Maps Nav. It benefits any app that uses the TTS engine.* Voices are cleaner and the interface may be a tab better on some NAV. No Homer Simpson voice on the android NAVI. Getting better with Google NAV periodically.
Not exactly. I leave GPS on all the time. It only chews through the battery when actively used. If you have apps that use the GPS receiver that you're not aware of you may find that battery life is improved by turning it off.* You will find that your phone battery will become mush if you don't turn the GPS off.
Assisted isn't relevant in the context of what you're saying. Assistance data is only used for the initial fix. The aGPS receiver can fall back on standalone mode if needed. The data requirement is determined by the app, not the GPS receiver itself. I'm not sure what you mean by your last sentence. The iPhone has GPS nav app options with locally stored maps (TomTom, Navigon, etc) just as Android does.* They are assisted and depend on some sort of data. I could see NAVI failing in rural areas so a no go for hunters etc. The Iphone failed on DATA only NAVI the Samsung Tablet owns so far.
Google navigation only works in the U.S. But you can still purchase navigation apps and store the maps on your sd and use it just like your garmin.
That is not true. It works in Canada and in many other countries as well. It also depends on what smartphone you have.
The stand-alone device has onboard maps. Google Maps nav doesn't. CoPilot and Navigon (as well as others) store maps locally if that's a must have. Locally stored maps can be beneficial if you're frequently in areas with poor to no coverage or travel internationally.
All of my android devices come with Google Maps. Since Google makes the android OS and it comes with that loaded I think folks can do the math. I already have two free GPS apps so I never felt the need to try others. One huge advantage of the phone. You can't use a different NAV on a mount GPS. However not all GPS units or apps are created equal so it is good that you pointed out some options.
Cool I will check this out. This may be a cheap way to get better voiced.
You must be disabling location services or doing something extra becuase GPS has drained the battery for my EVO, Iphone 2 &3 G, and Hero. Either ways it is much simpler to turn the GPS off vs. disabling location services etc on my devices.
Have you actually used an iPhone without cell service as a GPS on a hot spot? Or a tablet? I have and I beg to differ. Tom Tom lost satellite signal more than 50% of the time and greyed the screen out ie it stopped routing (over 1 gig of maps on the device). My TAB will stop routing without hot spot and the "GPS" will stop routing even in the middle of the trip. So it is assisted in some way. The Iphone 3G needs cellular to triangulate. The Galaxy Tab just needs my hotspot. I am sure not all devices are created equally.
No, I have mine on all the time with nothing disabled and my battery is fine. It all depends on whether you have apps actively using it. This includes apps that may be using it in the background. On most android phones, a satellite icon will appear on the notification bar when GPS is active. If it's not active, there will be no icon, and it should use up any juice.
Assisted GPS is only used to locate satellites to get an initial fix or when you're in area with poor gps signal (ie in a city with lots of tall buildings). In your context, in rural area with view of open sky, it shouldn't have any problems in maintaining a lock on satellites.
A-GPS - How Assisted GPS Works in Cell Phones
Math has nothing to do with it. Not all GPS app solutions are equal. Google Maps Nav doesn't fit every single user's needs/wants. Whether Google created Maps and Android and whether it's preloaded or not are irrelevant. "Best" for you may mean those things but it doesn't for everyone out there.All of my android devices come with Google Maps. Since Google makes the android OS and it comes with that loaded I think folks can do the math.
Your loss IMO. You don't know what the alternatives have to offer if you don't try them or at least read up on them. However, if you're happy with Google Maps Nav then by all means stick with it. It's actually my primary GPS nav app.I already have two free GPS apps so I never felt the need to try others.
No. It's as I said and as explained above by dylo22. GPS only drains the battery when actively used. As mentioned above, Android devices will notify you in the notification bar when your GPS receiver is actively being used. If there's no notification and your GPS receiver isn't in use then GPS will not drain your battery when turned on. There's an important distinction between "on" and "actively used" that you're missing. The iPhone 4 also sticks an icon at the top of the screen.You must be disabling location services or doing something extra becuase GPS has drained the battery for my EVO, Iphone 2 &3 G, and Hero.
Not under such specific conditions. How do you navigate while at a WiFi hotspot? Seems counterproductive.Have you actually used an iPhone without cell service as a GPS on a hot spot?
I'm lost as to what this has to do with cell service. Cell service has nothing to go with GPS. Also, your iPhone's GPS receiver lost satellite signal, not the TomTom app. Obviously, TomTom can't route without GPS signal but there's an important distinction here that you're glossing over.Tom Tom lost satellite signal more than 50% of the time and greyed the screen out ie it stopped routing (over 1 gig of maps on the device).
We'll have to agree to disagree then. IMO you're drawing incorrect conclusions from a lack of understanding.I have and I beg to differ.
You're confusing "GPS app requires data" with "assisted GPS receiver". Assisted GPS specifically means that the GPS receiver contacts assistance servers (if available) for a faster initial fix. Assisted has nothing to do with any data requirements that the GPS app may have.My TAB will stop routing without hot spot and the "GPS" will stop routing even in the middle of the trip. So it is assisted in some way.
They're not. However in all devices the GPS receiver and the GPS app(s) are separate entities. You're lumping them together. Make sure you understand what the receiver requires versus what the app requires before arguing.I am sure not all devices are created equally.
