Help Nds4droid on lg connect?
airtioteclint
Android Expert
Does anybody know if it will run on lg connect? I keep getting error messages whenever i try loading any roms. It won't recognize any roms in their zip forms and says to make sure they're in nds files. I renamed them to nds but it still no go.
I wouldn't waste your time. I tried it before out of curiosity and only got around 1 FPS (guessing since it doesn't even have a FPS counter). Unless some major performance improvements happen it won't likely ever be playable on our devices (maybe dual core support). On top of that, I've read that development has been discontinued. Even if that isn't the case, this one isn't going to be playable right now, possibly ever. Sorry
Yeah I was just checking out a youtube video and apparently it only plays in non landscape mode anyways. That combine with a thousand buttons means bad play experience. This makes me sad inside.
Thats weird. I have it running fine on my connect. It plays super mario 64 pretty good. Not laggy at all, and has a landscape mode. Very nice app. And the roms you put on the sd card have to be .n64 files not .zip or .rar files
Can you link me to the apk?
The OP is attempting to emulate the Nintendo DS, you appear to be using a Nintendo 64 emulator... two completely different consoles.
That being said, only emulator I use at the moment is Snes9x EX, possibly the best Snes emulator for Android I've found thus far... not to mention its free...
Right.
For SNES I use SNesoid. It was one of my first emulators along with Gameboid and the both of them worked so well I never bothered trying any other. I still play them way more than FPse which is the only one I paid for. :)
