Im trying to root using the instructions on [TUTORIAL] IDIOT-PROOF Root Guide! Thread. At step 29 the file to download the custom recovery is not working....anyone know of a fix?
Well the instructions are right there on step 29. If the clockwork mod won't work, then download the file that is attached. Rename it to update.zip, put it on the root of your card, and it should flash through clockwork mod. I am not too familiar with clockwork mod seeing as i went with amon ra's recovery, but that should do it.
