shahabazas
~*~ Android Addict ~*~
Please someone provide a complete detailed Guide/Tutorial to Convert Deodexed to Odexed and Odexed to Deodexed with all the links for the required application and all other stuff.
odexing the system is very easy
just open titanium backup pro
press options then select "integrate sys dalvik into rom"
for deodexing just select the option undo those integration in tb
If its so simple than we can have more good ROMs with both odexed and deodxed version.
aayush is correct
to make it clear it will work on blue terror
but if u flash firoz's update that dialer and those modified things will be gone
Yes TB does Not Work with All the ROMS !!
But i prefer Everyone Use Dsixda's Kitchen for Deodexing ! (Since starters are not gonna Deodex, Kitchen won't be a problem)
I think I have to make a One-Click Deodex and Odex Application in Google Play Store, for you all to do it.
Targeting "Indian" users and "With AD's"....
Hmm, whats say??
Hmm, whats say??
one more odexing app should also odex framework folder...we want one like that
