Root Need a favor!
JollyRoger87
I was wondering if someone would kindly upload their build.prop file here so I can compare it with that of the Andro-Id rom I've been using. Specifically to see if I can change how google sees the phone so I can open up market access for our triumphs.
Thank you
stock
# system props for the data modules
ro.use_data_netmgrd=true
# system props for telephony modules
#device supports ehrpd
ro.config.ehrpd=true
# system props for the mm modules
media.stagefright.enable-player=true
media.stagefright.enable-meta=true
media.stagefright.enable-scan=false
media.stagefright.enable-http=true
# {{[fb0.fc-7] enable qualcomm 2030 qcril log, kimchou, 20101221
# system props for qcril log
persist.radio.adb_log_on=1
# }} [fb0.fc-7] kimchou, 20101221
#georgeccchang, avoid emergency page pop up
keyguard.no_require_sim=true
#fxpcaym-141: Fix branding
#vmu wants "virgin mobile" for the values below. I can't get the makefile product_property_overrides value to treat spaces nicely so i'm putting them here
ro.cdma.home.operator.alpha=virgin mobile
gsm.operator.alpha=virgin mobile
#fxpcaym-175: Customer specific prop request
wifi.supplicant_scan_interval=90
ro.telephony.call_ring.delay=1000
#fxpcaym-198
dalvik.vm.execution-mode=int:jit
#div2-conn-ec-switchwapi-01+[
wifi.wapi=0
#div2-conn-ec-switchwapi-01+]
#fxpcaym-274: Start - hardcode numeric/country code
gsm.operator.iso-country=us
gsm.operator.numeric=311490
#fxpcaym-274: End
# additional_build_properties
ro.setupwizard.mode=disabled
ro.com.google.gmsversion=2.2_r8
ro.com.google.clientidbase=android-motorola
ro.com.google.clientidbase.yt=android-motorola
ro.com.google.clientidbase.am=android-motorola
ro.com.google.clientidbase.ms=android-motorola
ro.com.google.clientidbase.gmm=android-motorola
ro.opengles.version=131072
ro.config.notification_sound=onthehunt.ogg
ro.config.alarm_alert=alarm_classic.ogg
ro.cdma.home.operator.numeric=311490
ro.sf.lcd_density=240
net.bt.name=android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
Thank you
should be the
ro.build.fingerprint
line, should be able to change it to one of the newer phones that are on gingerbread to unlock all/more of the apps
and austrie i dont think thats the full build.prop
this is as close to full stock as i have, the only thing thats changed is the id which is just the name of the rom it shouldnt affect what ur looking for http://www.mediafire.com/?ibbd231r5xyt11p
Thank you
How's Andro-Id working for you? What's not working with this ROM?
3g and 1x otherwise it's been flawless so far though I haven't tested GPS or bluetooth, Good battery life too. First time I've been able to unplug my phone and 3.5 hours later the battery is still 100%, granted it wasn't being used but I've never been able to go that long without dropping not even 1%... Also the back, home and menu keys are mixed up, but you get used to it.
Are you able to make and recieve calls?
Yeah calls and texts both... It will tell you on the lock screen that the RUIM card isn't present so you can only make emergeny calls but thats false. You can call anyone and text anyone...
Makes me wonder if you can make outgoing calls even with a phone that has had its service suspended but I highly doubt that
Anyone with some know how willing to provide me one more favor? I'd like to someone to possibly make me a flashable zip that has either the stock build.prop or the one containing the evdo addition I don't really care either way. I changed the fingerprint and got nowhere and so I'm going to start changing numerous other items until I can get the phone to hopefully read as a Gingerbread Thunderbolt as that phone is closely spec'd to ours and has tons of market access. I'm likely to to get lots of bootloops trying this so having a fresh zip to fix the phone would be very appreciated.
EDIT: Nevermind just did some research and made it myself
