I had a Evo that I rooted with no troubles. He decided to go on a toilet snorkling mission and I had to get him replaced. (RIP) So this new on I got, seems to not want to root. I have a Macbook Pro and dowloaded the software I needed. At first it said my OS wasn't compatible with the download from the unrevoked site.(This ones icon said EVO^3) Then I found another program that works with my OS.(this one says Evo^2)
When I run the program and do everything as the guide says, it will start working but it always says something to the affect of cannot flash program or something like that. So I downloaded Z4 root to try and go that route and it wont root my phone either. The temp root works just fine but I can get the permanent root to work.
Is there something I may be doing wrong? Im not savvy enough to do the other way in the troubleshooting section or else I would have tried that already. Any advice would be great.
