Gman9831
I'm no Senior
If you have a motion and your in NYC can you tell me the spectrum configuration currently
To check: If you already know your service code skip to step 3
1. Go to android - whiterabbit.org
2. Enter your IMEI where it says MEID/ESN then hit calculate write down the six digit MSL code
3. In the dialer enter ##626* then when the service code box pops up put the 6 digit MSL code in
4. Go to field tests & then click screen & the channel bandwidth is at the bottom.
You have to be on stock
