kennersblack
Member
What app to use to stop all the pop-up ads on the internet
Ad-Blocker is what I use.
Hey can you send me a link to the one your using cuz I try looking for it but I can't find it
Here ya go. It's been removed from the Play store but there is a link for it in this post over at XDA. You will need to put it on your sd card and then install it. Make sure you have UNKNOWN SOURCES box checked in your settings so it will allow the installation.
http://forum.xda-developers.com/showpost.php?p=39144524&postcount=1
