Root Need assitance on RSDlite failure
stedrocklp
Member
I have tried a few times now to flash the ese53 sbf file. I want to do this to get the udated baseband but it keeps saying fail and then rebooting. Unfortunately when I check I have the old baseband. Any help would be appreciated.
Ok you can disregaurd. I finally got it on my seveth try. I am now rerooted with the new .03P base band. It only took three and a half hours oh well.
Im having a problem with RSD Lite as well
Here is most of the details i have.
Im running windows 7 x64
motodroid with ultimate droid 8.1
I connect the droid to usb, power off the droid
reboot holding up to get into bootloader mode
I run the newest version of RSDlite
it detects my phone, but when i point the RSDlite to the flash file, it gives me the platform is not defined for CDMA_type-msm6800-chipset error , almost instantly when i try to flash the new sbf file
Well i finally got everything i need to install the sbf file, but now im not going to get to do it now. I can't get the stupid android SDK pack to install to my PC so i won't be able to root my droid after i flash the new baseband. Two damn days wasted for nothing! Could i just load droidmod back on my card after the sbf flash and root that way?
Yes.
