Root Need camera APK
666Fritz
Long story short, titanium back up, freak accident, ended up removing "camera 1". When trying to restore it just sits at "restoring app" and never completes. Anyone have a solution, or can toss me the camera APK?
thanks in advance!
(not sure if you need both) throw these in the titanium backup folder on your sd card --- (just in case, back up your sd card first)
com.android.camera-20111203-100305.properties
com.android.camera-20111203-100305.tar.gz
Thanks a bunch! but, sadly I seem to be having the same problem still. Just sits at "restoring app". Also when using root explorer I can locate the camera apk in system/app/com.android.camera.apk. However, when I try to install it though it fails.
At a loss of ideas, do have a replacement plan with the place I purchased it. So maybe I'll just unroot it, and factory reset and trade it in for a new one :P
Unless someone else has a solution!
But thanks again for supplying the files, no clue why that didn't solve the problem:mad:
Upon further investigation of the /system/app folder I noticed all the APK files have a "partner" odex file. IE contacts.apk has contacts.odex right after it. From what I see, my camera is missing com.android.camera.odex. So MAAAYBE I need "Com.android.camera.odex" sent to me!
