Hi all...I've been learning/watching videos about rooting for a month now.
Want to root my desire but really scared as I looove my phone, Also have doubts if really should root as my phone works great as it is. It's super fast (only had for 2 months) and never had any problems with it so far. Keep thinking what if I root and performance is not as good.
I have a vodafone contract and think it's a branded one. I have no vodafone logo when turning phone on, the only voda word/sign I can see is on the unlocking/slide down bar and when I drag down the notification bar. No apps associated to vodafone.
running 2.2
Baseband 32.49.00.32U_5.11.05.27
Kernel 2.6.32.15-g263d94 htc-kernel@and18-2#4
Build number 2.33.161.2 CL284385 release keys
Software 2.33.161.2
Browser Web.Kit 3.1
I already found out it's Bravo PVT4 S-OFF (erase size value 20000) Good news right ? So I should use unrevoked 3.21 and should work without the need to flash amonRa instead of standard Unrevoked recovery image. My latest doubt is (doubts change everyday) do I need to make a goldcard before rooting. I find making a goldcard a little complicated and would rather not making one if I don't need to. I managed to find the exact/right RUU and it's safe/downloaded to my computer.
RUU_Bravo_Froyo_Vodafone_UK_2.33.161.2_Radio_32.49.00.3
2U_5.11.05.27_release_157522_signed.exe...
The above matches my phone.. Am i correct to think I don't really need a goldcard because of this. Would I be able to (if I needed to) unroot by just using this.
Or should I make a goldcard just to be safe and if so is there any easy method of doing it. I have a spare 4gb sdcard that came with phone and replaced this with a 16gb sandisk class 2. I found gparted a little complicated and I don't have any type of card reader and can't insert card into my laptop. I don't understand the benefits of debranding/unlocking so not terribly bothered about it. Would be happy to know I can use ruu to return desire to original self without having to worry about a gold card.
Thank you in advance for any advice...
running 2.2
Software 2.33.161.2
Browser Web.Kit 3.1
