Root Need Expert help plzz (about root)
plz help me ,i hv wildfire s 2.3.5 s-on,followed every tutorial on this forum of ROOT but didn't able to Root my device ,i followed CafeKampuchia's tutorial ,get UNLOCKED successfully ,but stuck at root part ,after installing clockwork recovery when i go to RECOVERY ,phone show HTC screen and then it get restart ...i thing recovery image didn't get flashed ,, tried many other imagess too ,plzzz help me plzzzzz
wasted 2 days on rooting but didn't get ROOTED my device
Hi,
Try Installing 'ROM Manager' from Play store. Run Rom Manager and flash 'ClockworkMod Recovery' option from it.
Reboot the device then check CWM either from hboot menu or from ROM Manager.
If it doesn't work post it back. :)
Hi im finding the memory and the battery life on my HTC Wildfire S very low i hav to charge it every day and i have to delete sum of my apps if i want to put sum new 1s on it. Any ideas r suggestions wuld be helpful
Buddy ... I was trapped in such situation too ... but I found a solution ... Pls tell me first that either your phone restarts at once after HTC sign ... or it shows blck screen with button showing lights ... ?
