Root Need FlyX help
jdaud
I have been running FlyX all day (awesome). However I developed a problem.....I have no access to my settings menu. Had access earlier in the day, then was messing around with some themes and suddenly it's gone. Anyone have any suggestions?:confused::confused::confused:
Have you tried rebooting?
Did you make a backup before messing around with themes? If not did you make a backup before going to FlyX? If not why? :rolleyes:
Recovery is a wonderful think but only if you use it.
I did. I did. I did. I have a backup pre-FlyX and post-FlyX. My main question I guess is whether there is a way to figure out what is 'missing' with regards to my settings menu and re-inset the appropriate files
Not that I'm aware of. Its much faster and easier to just restore and try again. It may have just been a fluke
I'd restore your pre-flyx backup and then reinstall the flyx.
only reason i want to is because i have FlyX but then loaded the gala x theme and now NO SWYPE..i love the look and everything but my noobiness to this got me in a pickle
You can't remove it you have to go back. You did make a backup right? What is the pickle? the gala x theme or no swype? You can always reinstall the swype.apk and I thought Fly final had swype.
FlyX definetly does has the option to add swype after its selected. The box pops up and swype can be checked or left out.
