Isn't it included in most of the roms? I keep deleting it from every ROM I flash. If I knew how to pull it out of CM7 and post it I would mate.
Let me see what I can find, and I'll post it for you.Nope, man.. not in my ROM. I'm currently on Supersonic Beta 2 XL.
EDIT: This app came out of the most recent Runnymede ROM, so it should work with what you're running: HtcFMRadio.apk
Probably, but some of the files in the HTC app might be tied to the specific framework files of the Sense version. So it's possible it wouldn't work unless the app is from a ROM with the same version of Sense. That's why I pulled the version from the Runnymede. I'll have to test this theory out later .In the future, all you have to do is download a stock ROM and pull it out of the system/app folder
Wow, I didn't know that I can do that. Worth to try.
