This is very nice. I hope they produce much more game like this. Or some FPS would be nice... I mean real games...
Please Help Me )Lets just hope some more main stream games make it to the mighty Droid now. NFS Shift is AMAZING. Graphics are stunning, and runs like a wet dream.
I'd love to see the likes of Call of Duty, Bioshock, Assassins Creed, and a few others, instead of the crap isometric, or sideways scrollers we have now as mainstream titles.
Shame tat we'll never see any HUGE RPG games like Fallout 3, Dragon Age, or Mass Effect, on our bad boys.
I take it back. Just checked out Gameloft. Some of those new Droid games look stunning.
How to: Force (all) apps to move to SD on Froyo
NO ROOT REQUIRED! (Thanks t0Msha)
First you have to enable USB debugging on your Android device from Settings > Applications > Development > USB debugging. Now you need to download and install the Android SDK on your computer from http://developer.android.com/sdk/.
Once you’ve downloaded and extracted the package to the folder of your choice, run SDK Setup.exe and click on Available Packages to the left. If you get an error message at this point, enable “Force https://…” in the Settings. From the list of available packages, select “Usb Driver package”, click on the Install Selected button in the bottom right corner and follow the prompts.
Connect your phone to your computer with a USB-cable. Your OS will prompt you to install new drivers. Choose to install them from the android-sdk/usb_driver folder. Do not mount your device; you only need to plug-in the cable.
Next, run a command prompt and navigate to the Android-SDK\tools folder. In Windows, this is done by selecting Run from the Start Menu (or by pressing Win+R) and typing cmd. You change drives in the command prompt by entering the drive letter followed by a colon), and change folders with the CD command. For example, to enter the Android-SDK folder, simply type cd android-sdk.
In the Android-SDK\tools folder, type in adb devices and you should get a serial number starting with “H” in return. All you have to do next is entering adb shell pm setInstallLocation Voil
i cant seem to install it on my desire 2.1 unrooted.
they said i do not have enough space.. my internal memory is only 147. how much does this application need?
thank you. d.knight, i just gont my desire put it on works like a dream
live a little
Sorry about the broken link the guy running the blog decided to stop supporting the advice therein:
Here are the instructions:
How to Install Apps to the SD Card by Default on Android 2.2 Froyo | larsa | Androinica
i did all of the above....the game installed but when i press the icon to play...first the ea logo comes up and then after a few seconds it goes back to the mobile home page !!! any help?No worries. You are right... easily best 3d game on Android at the moment. And it runs flawlessly on the desire. Some of the menus seem a little low resolution, but once you are racing it is very sharp and SMOOOOOOTH.
I highly recommend anyone with a Desire get this game!
For those unsure how... download the .apk file (after searching on google and MAKE SURE YOU GET THE VERSION FOR SNAPDRAGON).
Connect you phone to comp. Make a new folder called "NFS" at the top level of the SD Card. Then go to applications setting and select "run non-market apps" or whatever it is called.
Then open Astro file manager (free download from market) and navigate to .apk file. Click it and tell the phone to install. Install will take about 30 seconds.
Congrats... you now have best game available for Android. For Free!
