kegelinanger
Extremely noob when it comes to theming / modding, but I fugure practice makes perfect, so I'm attempting a little project to replace the battery % icons in an ICS theme for CM7. The theme is from the market found HERE. I would like to replace the battery % icons with THESE ones. I'm assuming since these are just .png files it doesn't matter that they're for a Galaxy S... or does it? I tried adding all the .png files to the drawable-hdpi folder in the ICS theme, and it worked for a second, but then it rebooted and the theme went missing from theme chooser. Tried to reinstall but it fails. I think the problem may be that there's fewer battery icons in the ICS theme (5% increments) than there are in the battery % mod (1% increments). However, when I switch to the battery % display in CM7, they are in 1% increments. I think these are the ones I need to replace, but I can't find where they are located. Hopefully someone understands what I'm trying to do and can provide a little assistance, or let me know if this is even possible with the files I have on hand. Alternatively, anyone who wants to do this mod and create a flashable zip, please feel free to do so
