need help after root
ok so i have a zte concord its my only option at the moment i tried to root it a couple days ago and i screwed something up when i started deleting factory apps also tried to restore all the apps aswell, have also tried to restore the phone via the method from settings, aswell as holding down power and vol - buttons to enter the screen to restore their aswell neither have fixed my issue
have also derooted device now aswell everything works fine except the following
i have no voice during calls made over the phone its self while i do have voice during calls made over voip apps like pinger, i have full sound to play and listen to mp3s, youtube, my voice search works the voice record works aswell so i know its not a hardware issue
also when i plug in a headphone or aux cable into the headphone jack the phone recognizes it has headphone attached but still remains playing sounds from speaker and not thru the headphone or aux output
please if you are able to help me pm as i dont check this forums or know if i can be notified if this thread is replied to
welcome to AF!!!!!!!!!!!!
you can setup your account here on AF to get instant email alerts whenever someone posts in your thread.
there are two ways to do it:
1. you can set it up so that anytime you create a thread or post in a particular thread that it will setup a subscription for it and you can choose how you want to be alerted whenever someone posts in that thread.
  • go to http://androidforums.com/usercp.php
  • scroll down to Settings & Options and select Edit Options
  • under Messaging & Notification find the Default Thread Subscription Mode
  • select the Instant email notifiaction
2. you can do it individually
  • go to the the first post in the thread
  • in green find the thread tools dropdown radio
  • select subscribe
  • a new window should pop up
  • select instant email notification
  • and then click on the add subscription
now on to your issue:
do you have a custom recovery? i'm not very familiar with your phone. there does not seem to be a whole lot of info for your phone.
if you do not have recovery then i'm not sure what you can do. this is why i will only root phones that has a decent dev community behind the phone for support. by deleting some stuff off of your phone there is always potential of breaking other features. without recovery you can't restore the phone back to its original state easily.
