My Admire Got Alot Of Problems
when you get the update su binary notification in superuser app
when i try to update this is what it says
downloading manifest
parsing manifest
latest version = 3.0.3.2
Checking installed version = 2.3.1-ef
Fixing database... okay!
Checking current install path... /system/
xbin/su
Downloading new binary... okay!
Checking md5sum... fail!
in all my times of rooting like 6 times i have never seen that
is this wrong because i never seen it
should i reinstall superuser or that superuser update fixer because i don't know about that update fixer like it fixes the update for the superuser app or the su binary did any of you admire users happen to you and --->---} IF YOU ABOUT TO UPDATE SU BINARY OR GOING TO DO IT LATER RECORD WHAT IT SAYS I NEED WHAT OTHER ADMIRE USERS SAY please i need help big time
parsing manifest
xbin/su
as have many people. Hopefully using one of the apps I linked will fix the issue if not I am sure there are plenty of people here that will be able to help and have lots of experience with the Admire
