Root Need help asap with cm 7 after install-Homescreen bottom missing??
Hello I just flashed cyanogen 7 exv9. rom When I finished it booted up I thought everything was fine, home screen looked good, but after a few minutes the bottom bar that has the phone button and the button to get to all the apps..it disappeared. Can someone please help me with this I'm a noob OBV and need some direction. thank you
btw I tried to go to xda and I wasn't able to post...WTF
After navigating to a few different screens and coming back to the home screen, it's back so I don't know. Is this going to become a problem?
sounds like you swipped the bottom part down. you can swipe down and put more icons in the bottom tray. to get it back just swipe up.
Its not a bug, you probably just swiped it down like huffman said. Its annoying and should be disabled in AWD Launcher, I find it useless...
yes this was not an issue or a bug, i was just getting used to it.
BUt now, I am having major issues with this.
#1 being 3g data is gone. It's missing from the upper right hand corner and when I try to anything with online, I cannot connect. Data is of course enabled but it's just not working. What's weird tho is for the first few days I had no issues with data, then all of sudden it cut off and I can't get it back. Basically without wifi, I cannot do anything requiring and internet connection. It's not Sprint right? It's the mod?
I don't know what to do...Is there a fix? or should I just go back to myns 2.2(first rom)?
It's a shame tho cuz i really really like cm 7.
any help would be greatly appreciated.
