Help Need help ASAP!!
Beanz123
OK, heres the story.
The other day, I randomly got a couple messages in my notifications bar at the top of my screen. They both had to do with low memory on the phone. When I tapped on it, it directed me to my application management. This is the part where im not afraid to admit I was a total idiot and decided it would be a brilliant idea to "Clear Data" on a bunch of them. Now, I was in the "All" applications list and started at the bottom, working my way up......not only did I do it to a few apps/games I downloaded but a BUNCH of regular OS things.....deleted ALL my contacts, my phone wont ring, my clock/alarm disappeared, among other things. Almost like I deleted pieces of the program or something. Im really frustrated, my boyfriend told me to do the power button+down volume+home button reset on it but it wont let me, he has done it to his and it fixed everything and deleted everything but his pictures, which is what im fine with doing since im already missing stuff anyway.... I dont know what to do!
Any advice??
You want to do a Factory Data Reset and start over?
menu > settings > sd & phone storage > factory data reset
Good luck!
Honestly I was hoping I didnt have to go THAT far but its looking like its my only option. Thanks so much for the help! I just have to get my pictures onto my computer and Ill get it done : )
